I am planning my storage compartment which is within 5 feet of my Battery box for my solar control center. I need to make room for the Charge controller which is very small and the 2000w inverter which will be big plus various switches and fuses.
Each device will need to connect to the battery bank. Is there any problem putting in a positive and negative Buss bars for connecting the inverter and Charger Controller OR does each one have to be connected directly to the battery separately?
I plan in putting disconnect switches between the solar panels and Charge Controller and a 50 amp breaker between the charge controller and battery.
I plan on a cut off switch and 200amp fuse between the Inverter and batteries. A positive and negative Buss bar would make things easier
