1L243 wrote:
Each device will need to connect to the battery bank. Is there any problem putting in a positive and negative Buss bars for connecting the inverter and Charger Controller OR does each one have to be connected directly to the battery separately?
I plan in putting disconnect switches between the solar panels and Charge Controller and a 50 amp breaker between the charge controller and battery.
I plan on a cut off switch and 200amp fuse between the Inverter and batteries. A positive and negative Buss bar would make things easier
I use a buss bar. All connections to the battery banks except for the temperature sensors are made on the buss.
Make sure you NEVER turn off the battery from the controller with the panels active, or you may let out the magic blue smoke.
I don't think a 200 amp fuse is quite large enough for the inverter.
Since I have twin battery banks, I use a pair of 350 amp fuses, for catastrophic protection, one for each battery directly on the positive post.
