time2roll wrote:
I was watching my battery voltage running the MW this past week with this in mind. My 4x GC2 drop to 11.9 right away when the Megatron is powered up using fully charged batteries. I also have about 5' of #4/0 wire. Easily ran the MW 8 minutes cycling 50%. I believe it could have gone much longer. Have run a solid 10 minutes previously but I was not watching voltage. I believe my GoPower shut down is about 10.0 volts. Voltage will always be artificially low at this high draw rate.
Manual says the Renogy 2000w inverters low voltage shut down is at 10 volts. I will have to measure at the inverter next time and use a second person in the cabin to run the microwave.
What kind of amp hours are you getting with your 4 GC2 batteries.
