BFL13 wrote:
You got to removing the inverter's neg from the shunt and then said nothing was now there, but did not list the 12v accessory.
Is the inverter's chassis ground connected to the frame?
Is the shore power plugged in? Where is the converter's neg?
I remove the first load from the shunt which is the charge controller and no short. I remove the next load which is the Negative battery to frame, no short. I remove the Negative load to the Inverter and the short appears. I remove the 12v accessory and the short is still present. At this point there is nothing on the load side of the shunt but the shunt is energized.
I also removed the fuse between the shunt and the battery
The Trailer is NOT plugged into 110ac.
The Converter ground is bolted to the Trailer frame.
