1L243's avatar
1L243
Explorer II
Jan 17, 2021
Calling on Solar Techies
I have been thinking of going solar for some time and decided to pull the plug.
My wants are a 400 to 500 watt system. I have four 12 volt batteries with 340ah. I am not planning on changing batteries at this time but will go to four 6 volts at 480 hrs in the future.
l would like to use an inverter so I can plug directly into the trailers 110 outlets.
besides TV's I would like to occasionally run electric heat and coffee maker and all the other things that go with RV use.
What size inverter would be recommended? Pure Sine Wave?
I would like a blue tooth controller and a automatic transfer switch and a auto smart charger.
It it best to look for a kit? or buy individual components? I plan on installing the system myself.
  • You would need a second trailer to haul enough batteries to run a space heater for any significant time. Adjust your expectations to running the furnace with the battery power and propane.
    2000 watt inverter could run any home coffee maker and your tvs. You can get the inverter with a built-in transfer switch and battery charging when plugged in. I always recommend sine wave.
    The solar controller is your smart charger. Review the available charge programming before you buy. Not sure why you need blue tooth unless you need one more distraction.
    If you find a kit with all the right parts I am sure that would make installation easier. I matched my own components.
    Enjoy the journey.
  • I see lots of issues, given your stated usage. Did you know small electric heaters draw up around 1600 Watts? Your Microwave oven also around 1500 Watts. Standard coffee pots - around 1200 Watts. .... are you begin ing to see the issue? You'll need at least a 2000 Watt inverter, and yes, pure sine wave would probably be best......and that is if you only run one major appliance at a time. A 1500 Watt electric heater through an inverter may pull around 120 or 130 Amps from your batteries when the heater is running..... how long do you think your 384 Amp Hour battery bank will last before it reaches the recommended half way point of that capacity? Frankly, you're going to need far more solar and a much larger battery bank to make that kind of power demands.... ConsideriLithium batteries and at least 1000 Watts of solar for this. I see you are in Oregon. Give AM Solar over in Springfield a call.....or contact them on their website and see if they'll give you an idea what you need. They are one of the best RV Solar companies in the country.
    . . . . Or you might just reassess your planned usage needs ..... the desire for electric heat would be your big killer.....
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 25, 2025
