j-d
Dec 04, 2016Explorer II
Test the outlet it's plugged into, with another light/appliance/device that you know is working. The light on our water heater lit up too, but the neutral from the source was open.
I don't know if you have a six (which I suspect) or ten gallon (not usually in a C) water heater, but the Camco kit is 500-watts give or take 100 depending on tank size. With the thing disconnected, power off, DVOM on Low Ohms, should measure a couple dozen ohms if the thermostat is cold enough to close its contacts.
And, I dispute your account of electrical incompetence. You ARE The Man who found that broken Stop Light Wire!!!
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
