Old-Biscuit
Dec 04, 2016Explorer III
Have you checked the t-stats to see if the High Limit Control has tripped......it has to be manually reset (Red button depressed) if it tripped.
If it did trip.....then the normal t-stat didn't open when it should have
If not tripped.......
Then with switch ON you should have power from switch to Hi T-stat (Blue wire) and then from T-stat (Black wire) to element. (With water cold so t-stat is closed)
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
