wa8yxm
Dec 05, 2016Explorer III
At the outlet it pluggs into check for power (Test lamp at least 100 watts, trouble lamp, drop cord, that kind)
At the element.. Disconnect wires and use Multi Meter to measure resistance, YOu should see 1 OHM or less (near short, meter may indicate a short) the element is less than 1 ohm hot.
The connector to the device has two round as I recall "hollow" contacts (Socket type) With the tank cold they should show power as well
NOTE, test this carefully
Run down
No power to outlet.. Well it don't work w/o 120vac,, Find out why
No contenunity in element.. need new element,,, odds are that is NOT your problem less you ran it dry.
No power at element connector.. Bad T-Stat-Bad cord-Bad plug.
T-Stat is suspect #1
Run down
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
