tictacball's avatar
tictacball
Camper black water tank fluid heats up
We do a lot of winter camping and always thought the furnace was keeping the holding tanks nice and warm. This past trip we noticed that the black water tank was especially hot and the furnace was not used. The only heat source was possibly the water heater. It had been left on over night by accident. The pump was off, but the black water was steaming! Any ideas before we climb in underneath to have a look at what could possibly be the problem?
  • 2012Coleman wrote:
    How do you know that the "black water tank fluid" is hot? :H
    I had the same thought :@
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    You may as others have suggested have tank heaters turned on (Electric heaters)
    Also black tank contents do tend to be warmer not hot but warmer due to biological activity. But I'd not expect it to be more than a few degrees.
    Hot water does not normally go into the black tank. well 98.6 degrees but that is Luke Warm.
  • Sounds like tank heaters are turned on. Kind of like "heated mirrors."
  • Do you have tank heaters to prevent them freezing?
    Make and model of rig?
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
