Locatuse's avatar
Locatuse
Camper electrical problem
I have a 1979 something 30 foot camper.
I have a power pole on my property with two rv hookups and two normal outlets. Gfci
My trailers rv hookup cord is not long enough to reach my power pole so I have a rv to normal outlet plug adapter on the end of my rv hookup cable with a regular extension cord that goes to the power pole.
I have four breakers inside this camper. One is for "general purpose" one is for "air" one is for "appliances" and last one for "lights". And in the middle of them is a "test button" that looks like a breaker that says if I press the test button the unit should trip and disconnect the power. I can press that button all day and nothing will happen to my power in here.
The problem is. Whenever I turn on the appliance breaker, the gfci by the power pole trips and the power to the camper is shut off.
I can have everything on in here minus the appliance breaker. I can have the General purpose. Air and lights breakers all turned to on and everything is working. The only thing not working are any of my outlets. So I can not plug anything in. The moment I take the "appliance" breaker from off position to on position the power shuts off. And nothing gets tripped inside my camper. I have to go out to the power pole and hit the reset button on my gfi and the power will come back on. That is only if I have my "appliance" breaker in the off position. I can have general purpose air and light breakers turned on and it will be fine. If the appliance breaker is in the on position. And I reset the gfi out by my power pole. The gfi by my power pole will shut off - reset- trip itself again
The even weirder thing is. I was in this camper a week ago and everything was fine. I had a heater plugged in and a tv going. For like eight hours. And then the power shut off. And it kept tripping out by my power pole. So I replaced the apliance breaker and tightened some stuff down. And it worked again like whoa easy fix. And about four hours later. Everything shut off and has been tripping out by the gfi power pole ever since.
Please help. Do I have a short in my trailer? A bad "test" breaker? A bad rv to extension cord adapter??? Should I replace my gfci with a normal outlet?
Any ideas? It'd be greatly appreciated before I start following all these wires for a short or fray. Which I have done alittle already and haven't seen anything.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
