dgcarlson's avatar
dgcarlson
Camper Parked; Freezing Overnight; No One Inside
We're visiting friends and our Lance model 880 sitting on our 1-ton Ford in the driveway, overnight temps will drop to the mid 20's. No one inside, only the refrigerator on, and NO AC Hookup - Battery only. Do not want to winterize the water system with anti-freeze for a 4-day layover.
Suggestions on how to keep the inside warm enough to prevent pipes freezing, but not drain down the batteries too much? Or is it hopeless?
Ideas I have: Open all taps with pump off; leave water heater on (plenty of propane); leave inside cupboard doors open for pipes
Contrary or additional suggestions?
- Dave in Bend Oregon
  • You are playing with fire! :B IMO. My son did something like this in Sep 2012 and ended up having to replace the plastic water valve on the commode.
  • Leave all the faucets open and put pink stuff in drains . or you could leave a faucet with a slight drip when going to bed so that the pump comes on once in a while. Check to see if pump still work in the morning. If it freezes use a hair dryer to thaw. Remember it takes hours of below 32 for the water to freeze. SO if daytime is above freezing you could be ok
  • With furnace on and interior temp at 60 degrees, cupboards open our MH would be okay. Except for the drain pipe running sise to side at the very bottom of the floor with only the metal under skin "insulating" it. If you have a pipe like that put $2 worth of antifreeze down the sink.
    Low point drains and the like also tend to freeze up on our rig at -10 C, 15 F. A sock or glove over the valve stops that.
  • Leaving cupboard doors open only works to provide inside heated air to the pipes. If you don't have a furnace/heater running, this probably won't help much.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
