SoundGuy
Jun 17, 2018Explorer
suprz wrote:
You can use your weber but only if you get an "extend a stay" device. It goes between your tank and the rv's regulator. And has all the appropriate fittings
Not the only way ... if the OP's Weber is a Q he can simply remove it's regulator and connect it directly to his trailer's quick disconnect low pressure fitting. He just needs a hose with a fitting that will match the Q's gas valve input and at the other end a male quick disconnect fitting that matches his trailer's female quick disconnect. Thousands if not tens if not hundreds of thousands of RV owners have done this mod and it works just fine.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
