Gjac
Dec 15, 2019Explorer III
I would clean the roof real good with soap, bleach and a brush, then power wash to remove any loose coating. Just use good sense when using the power washer not to get too close. An electric one between 1500-1700 psi works well, get all the mold off also. Check for any leaks inside, areas where new caulking is needed. After drying then recoat with with any number of coatings, Bus coat, Heng's, Henry's, Dicor, etc. The prep work to me is more important than the name brand coating you use.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
