Bobbo
Apr 15, 2015Explorer III
joebedford wrote:
If you have a sat receiver with external dish, you put the receiver where that jumper is now.
Without a picture, this is only a guess, but I believe joebedford is right. To use a satellite receiver, you hook the satellite antenna to the cable connection outside, then put the receiver between the two coax connectors you see. One is line in, one is line out. The jumper is so you can use the line as cable input without the satellite receiver.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
