taken
Apr 11, 2015Explorer II
Solved! Found that the tech wiring my camper had mistakenly put both circuits to be shed via the management's relay on the same leg. This this fooled the control panel into thinking it was a thirty amp setup as opposed to 50. Moved the circuit to the other leg and all is well with 50 amp showing correctly on the panel...
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
