taken
Jul 16, 2015Explorer II
If you look inside your breaker box, you will see plastic rings around the wire coming from the two circuits that are to be shed. If both those circuits are in the same leg of your service (left or right of the main breakers) then the load management system sees 120v instead of 240v. I pulled one of the breakers and swapped it's location with one from the other leg and all was well...
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
