zulu52's avatar
zulu52
Can I leave my T/C plugged in to A/C when not in use?
I currently have my T/C unloaded and sitting in my yard with a full cover on it. I have it plugged in to a/c.
If I unplug it, the carbon monoxide detector will run the battery down in about 10 days to two weeks. Then the detector starts beeping low power supply.
So I have just left it plugged in.
Is this okay? I have to disconnect and pull the battery completely out to check the water level but I have been doing this.
I am assuming that the onboard battery charger just charges when needed and keeps the battery fully charged.
Am I right in assuming this?
Just want to make sure I'm doing the right thing.
Thanks,
Zulu
  • It depends on the battery system that you have. If you have one that tops up and does not over charge you are good. I leave mine in 24/7/365 when not on the road and it is fine.
