stevekk's avatar
stevekk
Can I Modify Portable Gen Exhaust ?
Has anybody modified the way the exhaust was pointed on your portable generator.
Like rather than exhaust shooting straight out of the back,
installed a 90 degrees elbow?
A master small engine mechanic told me not to modify the exhaust since it would change the back pressure?
I have a Yamaha 2800 and would like to mount it on/ near the rear bumper.
But the exhaust would be headed straight into the back of the RV.
Any ideas? THANKS..
  • you would on an old B&S engine with a 3 inch exhaust/muffler
    newer designs with large mufflers have bolts/supports hoding the muffler/exhaust
    any weight there might affect the 'exhaust Tip' but not the engine manifold
    a number of people have modified the exhaust of the cpe 3000 generator,
    with good results and no harm to the manifold
    me i would use a piece of flexible exhaust wraped with heat tape and point that where wanted
    MEXICOWANDERER wrote:
    Careful with any extra added weight! It can fracture the aluminum cylinder head threads like plastic. You would absolutely have to design and install some kind of a bridge hanger to support the pipe bitter end.
    Any ideas? THANKS..
    Steve,
    Modifying Generators
    VERY long thread, but maybe search "exhaust" or "enclosure" - when building an enclosure for noise reduction, inevitably the exhaust requires modification.
  • Could you add a longer platform, like a receiver hitch carrier and turn the generator around or sideways?
  • Careful with any extra added weight! It can fracture the aluminum cylinder head threads like plastic. You would absolutely have to design and install some kind of a bridge hanger to support the pipe bitter end.
  • My dad had same problem. The easy fix was to turn generator around on the rear rack. Even if you add a 90 you will/might still have the heat hitting your rear wall.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 06, 2026
