Naio
Dec 20, 2019Explorer II
STBRetired wrote:
Make sure you use a long enough set screw that you don't have to worry about ripping out the last thread on the sprocket. Also verify that the keyway in the sprocket has been drilled all the way through so that the set screw does not damage the keyway.
I'm sorry, I don't really understand what you're saying. Especially the second part.
I found my sprocket: This is the one I currently have on the keyed shaft, and that I want to try to put on the D shaped shaft. I see this place is still selling them, so I can get another one.
http://www.staton-inc.com/store/index.php?p=product&id=1958
