GMT830
May 24, 2013Explorer
dougrainer wrote:
Installing a 50 amp end just bypasses the problem and will transfer the problem to the interior of your RV. That means since the plug will not overheat, because you have the heavier duty 50 amp end, then the end of the shore cord where it connects either a Transfer box or direct to the interior 120 breaker system will now overheat and cause problems.
Disagree. The current flow is the same through the entire shore power circuit. Fixing the weak link will not move the hot spot somewhere else. It is of course possible that he has multiple hot spots and doesn't know it.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
