swp5767ExplorerMay 24, 2013Can I replace a 30A plug with a 50A?I find that about once a year or so, I need to replace the plug on my shore cable. The hot leg of the plug gets hot over time and melts the plug can causes it to fail. The big difference that I see...Show More
2112Explorer IIMay 25, 2013Just to clarify; you ARE NOT using a 30A to 20A adapter, are you?Something like this?This will suffer a meltdown when used with the A/C.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
Related Content7 pin plug amperage rating?Glow plug replacement Pleasant surpriseWater Heater Replacement Recommendationsreplace transfer switch with 50amp plug?Replacing 30amp male plug
