mr_andyj
May 04, 2021Explorer
The main reason to run the gen is to move the awful ethanol gas through. For this you do not need a load to be placed on the generator head or the engine.
The other reason is to exercise the generator head, which you DO NOT need to do weekly or even monthly. It is good to do once a month or every two months, but depending on the gen it is not really that necessary.
On my old Onan I would let it sit all winter, and even a few years for one sitting, and all was fine. I could not tell any difference in either the gen or the engine.
If you will not use it for a while it is best to run the carb dry or at least use Stabil gas additive to keep the gas from turning to varnish in the carb. There are other methods of course...
As for transfer switches or circuit breakers or however your particular RV switches I, nor anyone, can say, that is particular to your setup.
My fav setup is to put a Y in the fuel supply so I can draw from the motorhome tank or draw from an aux tank which I have 100% gas so the gen is stored wtih 100% gas (not toxic ethanol). The gas will last longer than the alcohol and will last even longer with Stabil. Better yet to physically drain the carb for long storage.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
