DrewE
Jan 15, 2018Explorer III
The 9280 can power it easily; it's capable of supplying somewhere around 1000 watts. You would need appropriate wiring and fusing, 6 gauge or so wire. Most RV fuse panels wouldn't be able to have such a circuit, so it probably would require a dedicated connection at the battery or converter. That is assuming it's anywhere near the claimed 500W,...
Heat could be somewhat of a concern but it is spread out sufficiently that a bit of care and common sense should suffice to prevent trouble, assuming the light isn't dangerous by design.
I think this is far too bright for what you're intending, though. Also, as GordonThree says, the quality of the light will be pretty crummy. A halogen work light might be a reasonable and not too expensive alternative, though they do run hot so mounting or positioning should be done with care.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
