Gdetrailer
Dec 02, 2020Explorer III
campingwiththoreau wrote:
How can I post a photo? Don’t see an upload button etc...
It’s not the decal that cracking...it’s the entire
front of the trailer. I surmise- water is leaking in from
the roof ( even tho it’s caulked up there ) and the
front of the trailer material is delaminating.
Sadly- I need to repair as best I can as this
trailer is hurricane tied down and grandfatherd
Into the park I’m in. Once this trailer is removed -
another can not be placed on my lot with out major
hassle and the removal of an adjacent storage shed...
Otherwise- I’d give this trailer away & buy something
new. Hoping I can paint / seal the front & get a couple
more years out of this old trailer. I’ll upload detailed
photos once I figure out how to upload ????
This forum does not host photos so you have to use a online host that allows sharing to get a "URL" that can be added via the little Icon with yellow background with what looks like a sun and mountain (located in the "advanced posting")..
Max size is 600x480 if you are doing this manually so folks with limited bandwidth or limit screens can view quickly and with needing to scroll..
One of the members of the forum actually setup a cool online "app" which can upload any photo you choose from your PC or Tablet, upload it a online host and then it gives you a URL with the proper formatting for this forum so all you have to do is copy the entire link with formatting and just paste it into your post text..
You can access that HERE, you can book mark that location.
OK, yeah, entire front, it is either molded plastic like ABS or it is Fiberglass and resin (FRP).
If you are seeing little fiber like strands (looks like fine hairs) it is most likely fiberglass and resin which is a bit easier to "repair".
ABS and the likes, not so much because it has no fiber reinforcement and gets extremely brittle with age.
If you are seeing fiber like strands and no actual physical "cracks" through the material you can simply clean off any dirt or grime, lightly abrade or lightly sand the surface with a fine sandpaper (gives the paint something to attach to). And since you are in a campground, you can primer and paint the front.
You can use your favorite rattle can or you could go with roller and brush.. Some of it may depend on your campgrounds rules.. Just remember, those paints will not be as long lasting as automotive grade Urethane paints and you may have to reapply after 3-4 yrs in the sun..
On edit, you mention delamination, that is a whole different animal.., Delam basically means you will have noticeable bubbles or pockets below the surface when the plastic or FRP separate from the wood panel under it.
Those do not harm anything, they just look ugly. Although if it is from leaking you need to fix the leaks.. That means you most likely will need to remove all the old caulking and replace with new.. Slathering new over old isn't a fix, it makes the next repair harder..
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 18, 2026
