valhalla360
Sep 24, 2021Navigator
naturist wrote:
Do be aware that being able to start the ac at home when your battery is fully charged may not result the same in the boonies with a somewhat depleted battery. The converter will be trying to recharge that battery then and 2000 watts might not be enough.
Also at sea level it may work but get up 5-6k feet and the thin air will eat away at the available power...so you might have issues.
If you already have the 2000w generator, a soft start system is an option but if you need to buy a generator, makes far more sense to get a 3000w or larger generator, so you aren't reliant on everything going perfect.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
