TNrob's avatar
TNrob
Can one set the whole camper on jack stands?
I suppose it might be because stabilizer jacks aren't rated for load, but I've seen mention of frame twisting also. "Do not use jacks to level RV; use only to stabilize."
So, you have to work on suspension sometimes. How do you go about raising and supporting an entire camper on jack stands. I assume you have to do it on nearly level ground and have the stands set so that the frame is level once lowered. Do you use two pair at the corners, three with one near the spring mounts, a pair at each of the spring mounts and a pair to the front like is sits day to day anyway?
I'm just curious more than anything, but I could see doing it if one was planning to replace a bunch of stuff at one time.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 29, 2025
