DAS26miles
Jan 13, 2017Explorer II
Chris Bryant wrote:
I actually refill through the outlet of the tank- I remove the regulator and use the POL there with the double headed hose- just two standard old style pigtails hooked together with an inverted flair coupler.
With the cylinder above the tank you can hear the liquid flowing.
Any photos?
Since the Extend-A-Stay is already hooked up, can I just turn the tank up side down and open both valves?
The Extend-A stay is between the tank and regulator.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
