RJsfishin
Jan 14, 2017Explorer
Chris Bryant wrote:
I actually refill through the outlet of the tank- I remove the regulator and use the POL there with the double headed hose- just two standard old style pigtails hooked together with an inverted flair coupler.
With the cylinder above the tank you can hear the liquid flowing.
I do this same thing now and then to top off at home, and save the hastle of getting a few gallons. If you connect it in the evening while temps are falling, it transfers faster.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
