wa8yxm
Jul 17, 2022Explorer III
joebedford wrote:
My question is: is there a failure mode of the regulator whereby it leaks gas from the tanks? I didn't smell any but the rig is far enough away from the house that I might not.
Short answer is yes.
Longer answer. The Regulator. The hoses. The pipes and even the TANKS can leak any connection especially the tank connections if they are not tight enough.
I've heard claims that a full tank.. TURNED OFF. was empty a "Short" time later..... Was it? I do not know as it was not my tank.. I've had tanks however that were Full when I closed the valve and far from it when I returned them to use. CLOSED valve on the tank. and I close 'em tight.
