tpi
May 01, 2013Explorer
Pangaea Ron wrote:
Lynnmor
I agree about the check valve, thus my earlier question about pressurizing the tank. Upon thinking about it, even a plug should have a small hole to allow the tank to vent for expanding water, etc. I might (probably would) forget to remove it for use.
Re-routing the line seems to be the best option.
At least there has to be some kind of provision for venting pressure. Elevation changes come to mind and can create a considerable pressure or vacuum situation.
