TheLostBoy's avatar
TheLostBoy
Can the padded header over interior door be removed?
I have a Jayco Jayfeather and I need to remove the padded header above the door in the interior (so I can put a bracket to reinforcemy door opener). I removed the three screws that I thought were holding it on, but I've been pulling and pushing, but it won't budge! Is there any way to remove this without damaging it?
1 Reply
  • Try running a magnet around the cloth and see if you can spot any hidden screws. If you remember where the screws you pulled were located try prying up gently in that area to see if it's looser than other areas. It's possible that it's glued to the wall with a few screws to hold it while the glue dries.
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 16, 2025
