BFL13's avatar
BFL13
Explorer II
Sep 10, 2015
Can Tire Coleman (Sunforce) 100w Solar Panel Specs
Just for anybody looking at one on sale for the next few days, the actual specs are Poly, Isc 6.25a, Imp 5.8a, Voc 21.5v, Vmp 17.1v
(The label on the back of the panel wrongly says the 5.8 is the Isc and does not give the Imp, so I had to get that clarified)
It is smaller in size than panels made maybe 5 years ago due to some improvements in cell design, at 40" long instead of about 48" back then. (Talking to Sunforce tech support) The box it comes in is way longer than the panel due to packing.
http://www.canadiantire.ca/en/pdp/coleman-100w-crystalline-panel-0112099p.html#.VfHYXnmFOh1
I grabbed one even though $2/w is expensive for a 12v panel IMO, it may be difficult to find anything for much less these days "up here"
It works ok - in low full sun at 9am, I got 22.3 Voc and 4.8 Isc. Looks good for getting that 6.2 Isc at STC.
It comes with some extra wire tossed in the box but 5 mm gauge (whatever that is in real money!) I would use fatter wire of course.
  • i bought the 60watt version last year which i use as a portable setup in case my RV is in full shade, also use it to charge my boat trolling battery. Seems decent for the price, the 7amp charge controller i got with it seems extremely low end but seems to do the job. I agree with you about the wire being too thin and they even included an extension of about 20ft of the thin wire, which i try not to use as i expect it would lead to a lot of voltage drop. The small 60 watt panel is quite small and portable so for my intended use it works well.
  • 2oldman wrote:
    Page does not exist
    Fixed I think (it is slow)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
