BFL13
Jul 02, 2017Explorer II
Two dissimilar batteries in parallel where one is 85AH and the other is 150AH will be at the same voltage. Their bank capacity is now 235AH.
When a load is put across the pair, each will be drawn down equally according to its proportion of AH size. Each will reach 50% SOC at the same time and their voltages will still be the same.
IE their voltage will be 12.2, and capacities now will be 42.5AH and 75AH.
So you can camp with these no problem. You can do 50-90 recharges with them connected no problem. Where you have a problem is charging them back to 100%
So at home you separate them and get each up to 100% by its own specs. Now you can put them back in parallel and float them at 13.2 or so and they will both stay fully charged.
You cannot put them back in parallel and just let them sit with no float voltage or else they will self-discharge with one battery eating the other and all that bad parallel stuff. You could leave them separated and just sitting there for a while--longer when it is cold out.
Time2roll has always said leaving them on a float will make up for all that because there is enough voltage to keep them both up even if they each want a different amount and there is some action going on between them.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
