wa8yxm
Jul 04, 2017Explorer III
I do agree connecting Wet with AGM, not the best idea
As for "Balanced configuratrion"
Assuming you use common 4GA starter cable, which is super good for batteries in parallel (or series) unless you are using major power (in which case upgrade to multi-zero) the imbalance will not be anything you can measure.
Now if you are sucking MAJOR amps (IE: the 200+ of my 2,000 watt inverter) THEN balancing may be important... But for "normal" RV use.. not.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
