ScottG
Nov 18, 2013Nomad
My awning material is damaged by the sun so I looked into installing a whole new electric awning. I ran into a problem though...
Electric awnings require (per directions) some solid wood at the very top of the brackets so you can install two large lag-bolts. My TT has an aluminum channel, luan and styrofoam insulation up there so there's just nothing substantial to attach it to.
So if you have some 2X material at the top of your walls then you can probably install one but otherwise it may not stay put.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
