LittleBill
Oct 28, 2014Explorer
MrWizard wrote:
Inverter generators from different MFG, using different electronics to create the output power are not safe too connect together
Stream driven or water driven hydro turbines are synced by brute force
They bring them online by slowly applying load ( connecting to system thru inductive load) and using the back EMF to drive them into alignment aka synchronous spinning
Something you cannot to with consumer grade ( inverter output ) portable generators
i disagree, the inverters in the honda are nothing more then sync capable, just like every grid tied inverter on the market for solar.
i see 0 reason for it not work, im pretty sure the honda will work with any generator inverter or not.
now if they carry the load equally is a different story
flame suit on !
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
