24rules
Jul 10, 2013Explorer
i guess i am confused why you need to run welding cables, is this for a 12 volt system or a 120 volt. 2 number 6 thhn style wires which is designed to go into conduit have a thinner coating on them will have no issue at all in a 3/4 pipe the welding cable is much thicker because of the exposure that it comes in contact with when it is used as a welding cable and also the 12 to 15 amps that you talk about is far below what a number 6 gauge wire is rated for which is somewhere around 60 amps or so
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
