cavie
Aug 29, 2019Explorer
You can only access 240 volts in an RV that has been designed to do so. 90% of RV's are not designed to access 240 volts from the panel. If the main breaker is in the middle of the panel than no, you cannot access 240 volts. If your RV has a 240 volt washer and dryer then yous you can do it.The main breaker will have to be on one end.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
