Gdetrailer
Jul 18, 2022Explorer III
2oldman wrote:Gdetrailer wrote:We're only talking about a few inches of conductor.
While that can be made to work, iron and steel have a much higher resistance for the same equivalent size, thickness and length of copper.
We're only talking a few "inches" of copper also..
When one is trying to get the full potential from their 12V battery system, adding any "conductor" which has more resistance isn't really a smart way to go.
There are commercial purpose made copper buss bars available for reasonable prices, takes less work than repurposing material of lesser qualities and results in far superior performance.
Barring using a commercially made purpose built copper buss bar then simply hammering a 1/2" piece of soft copper pipe flat and drilling a couple of holes would be preferred over steel.
If neither is available then connecting multiple connections on the same battery terminal would be superior the preferred way over a steel buss bar.
Not saying it doesn't work or won't work, but heck, if one is going to the expense and hassle of setting up a power distribution system with buss bars wouldn't you like to get the maximum bang for the buck?
There IS a reason you don't find steel being used in your home and commercial wiring systems..
Auto manufacturers do cheat by using the vehicle body, but consider that there is a lot of steel involved which offsets most resistance losses.. But, there are still losses and as the vehicle ages and has been run through many winters of road salt often those remote ground connections start to fail..
