ADAD437
Aug 24, 2015Explorer
vic46 wrote:
I wonder if it is the blinker device itself. It will likely be located under the dash on the driver side. It will look like a plastic cylinder, perhaps clear, that is likely about 2.5" long by 1" in diameter.
yep the flasher is where i would look, check for voltage at the socket, as has been stated the turn signals are not fused seperate. if the fuse goes all turn signals will not work. the flasher can let one side work and the other not.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
