harold1946
Aug 26, 2015Explorer
wa8yxm wrote:Muddydogs wrote:
Blinkers aren't fused, check the bulb, wiring and trailer plug. Your outside trailer lights (blinkers, brakes and running lights) are a separate system from the inside trailer wiring and do not run through the trailer fuse box.
Is your TV blinker working? If not then look at the TV fues box first.
Most likely its the bulb.
Mine Are.. I know.. I blew the fuse. 2005 Intruder, Workhorse Chassis
You are correct on the Workhorse chassis there are two fuses. One for the right and one for the left. They are located in the under hood fuse block and are 5 amp.
The marker lamps fuse is located in the interior fuse block, position 17 and is 10 amp.
If the track lighting is 12 volt there will be a fuse in the 12volt panel in the coach.
If it is 120 volt there will be a breaker in the power panel. If not connected to shore power they will not operate unless the inverter is on.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
