csamayfield55x
Aug 04, 2015Explorer
It probably has a burned out element. If you have a multimeter you can check the element leads and look for resistance.Make sure power is off when you do this If there is resistance then you need to check for voltage. If you are not comfortable around electricity then get someone who is. Those are live 120 volt and will reach out and bite you
Chris
Chris
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
