brows827's avatar
brows827
Can't get 12v power and boondocking
Hi - I'm a newbie RV'er and I'm having an issue. You guys have helped me before, and I'm hoping you might be able to help again. My Rockwood Roo 19 (2014) has been in storage on shore power for a couple weeks, and I just picked it up for a weekend boondocking. When I picked it up, I was getting power without a problem and it showed the battery full (it was also hooked up to the car).
I arrived and got set up, but now I'm not getting any 12v power. I checked my circuit breakers on the converter - none are tripped and fuses are good. I switched the converter circuit breaker off and back on and the fan runs for a couple seconds then stops (maybe since battery is full?).
After I disconnected from the generator, I checked the panel and the battery briefly flashed full, then nothing. Can't get any power to it.
Any ideas what the issue might be? Bad connection? Bad converter? It's a new battery so that hopefully shouldn't be the issue.
Thank you in advance - as always I appreciate your insight.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
