cochise49
Nov 06, 2013Explorer
Bob/Olallawa wrote:
Are all the water control valves in the right positions and the water line from the tank to the pump hooked up.
Good questions...not sure. I was able to feel a disconnected line and tried to reconnect. Not sure if it is tight. They apparently pulled the cover from the utility panel and had to remove the valve handles to do so. The valves were in the right places when I filled the tank. Haven't been brave enough to pull the panel myself yet. Getting there though.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
