lost_texans
May 18, 2016Explorer
Old-Biscuit wrote:
There isn't one..........
Is this first time in a while that you have used the propane system?
If YES..it can take a while and several tires to get propane flowing to each appliance......farther away from propane supply (tank/cylinder) the longer if can take
Is that Atwood water heater a Pilot Flame Manual Light type OR a Electronic Spark Control type? (Model Number)
This is the first time ever; We just recently acquired the MH.
It has a piezo spark set up. Model G6A-8E.
There is supposed to be a rocker switch on one of the panels.
Fridge and furnace work fine.
I may just have to do a kludge wiring job.
Previous owner not available to ask.
The printed circuit board control was replaced by a major chain RV shop. I have some questions about the quality of workmanship.
I'll go over all the spade connectors, as invisible corrosion is fairly common here with salt on the roads.
Thanks for the response.
Jim
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
