Sjm9911
Sep 01, 2020Explorer
Yes. The CO alarm is carbon monoxide ( not CO2) that is set off by incomplete combustion. If you are not burning anything, its probably not that. The propane alarm, and that sounds more likely is what you are describing. ( some detect both) Check the conections and the lines. Soapy water. Then check the detecter itself , they go bad after 8 to 10 years and need replacement. Ive also herd the sewer gas can set off the detecters, probably the propane one and not the co one. See whats going off first. Then check back here.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
