InTheRockies
Sep 02, 2020Explorer
Carbon Monoxide/Propane Alarm - Propane Leak?
Hi all. My travel trailer has been sitting in my driveway since June and yesterday I heard an alarm going off in the trailer. It was the combo carbon monoxide/propane alarm, which has never gone off before (I bought the trailer new in Jan 2019). I opened the door and left it open for a bit. Alarm kept beeping (three or four beeps in a row, a pause for a few seconds, and then repeating).
No appliances were on. The propane bottles were connected but the valves were turned off and had been for the last three months. I hit the test and mute buttons on the monitor which silenced it temporarily, but then it went off again. As it wouldn't shut off, I disconnected the trailer battery and disconnected the propane tanks. Of course it stopped then.
I let the trailer air out for a while and then closed it back up. I reconnected the trailer battery to see if it was maybe an electrical issue, but it didn't start beeping again. I then reconnected the propane tanks as a test and about 4 hours later, the alarm started beeping again. I've since disconnected the propane bottles. When the alarm stopped beeping the 2nd time after disconnecting the bottles, the green light on it was blinking. I disconnected the trailer battery and reconnected it and the light on the monitor is now solid green.
So, what I'm surmising is that I have two issues - the first is that at least one of the propane bottles is leaking (I'll try the soapy water test tomorrow to see which one). The 2nd issue though is that even if propane is flowing from the bottles, how is it getting into the trailer, unless there is a leak in one of the interior lines or appliances.
Any thoughts on where and how I should check for the interior leak? I live in a very rural area and am not close to a RV service shop. No mobile techs out here either. There is a propane shop about 30 mins from me and I'll call them tomorrow to see if they troubleshoot this kind of thing, but if I can try and pinpoint or at least rule out some locations of the leak, it would likely save me time and money.
A couple of other notes: it's been quite warm here - upper 80s during the day and likely warmer than that in the trailer. I've read that sewer gases from the black tank can sometimes trigger the alarm, but it's not started beeping since I disconnected the propane tanks.
I did recently have an issue with mice in the trailer (within the last couple of weeks). I seem to have gotten rid of them, but could they have damaged something in the propane lines? I also noticed mouse droppings on top of both propane tanks when I took the cover off.
Thanks in advance for any suggestions.
