pianotuna's avatar
pianotuna
Nomad III
Jul 16, 2013
care, use and feeding of a Yamaha 3000 iSEB
Hi,
Does anyone run 1200 watt air conditioning on the Yamaha 3000 iSEB using the eco switch?
What sort of routine maintenance do you personally perform?
  • Without sounding like a smartarse, I just add gas. I change the oil every spring (sometimes) and that's literally it. I can't comment on the 1200 watt air con but mine will kick up when the microwave is used or DW uses her 1200watt hair dryer in Econ mode.
  • mena661 wrote:
    I take it putting gas in it is not enough? :)
    Thats pretty much all you need to do with a Yami. Change oil every now and then. It just looks after itself.
  • Hi mena and mex,
    Well I was hoping that some one would know...I guess I'll try it and find out?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
