bjlakatos1
Mar 06, 2017Explorer
dougrainer wrote:
...shorted someplace between the switch and the motor...
If I direct connect the battery to the awning motor wires at the switch it operates normally.
If I direct connecct the battery to the power wires of the switch, the Switch operates the awning normally.
You do bring up a good debug point, to switch the wires at the motor and see if it follows a wire (or the switch).
Thanks, will keep you posted on my results.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
