bjlakatos1
Mar 09, 2017Explorer
dougrainer wrote:
Since you have replaced almost all the parts, one thing remains. When you extend and retract all the switch does is reverse the polarity to the 12 volt motor. Since it ALWAYS works extending and blows when retracting, that points to the wire when retracting that is POSITIVE is shorted someplace between the switch and the motor. REVERSE the 2 motor wires AT the motor. That will extend the awning when pushing retract and retract when pushing extend. See if the failure now happens on extend. If it does, your 2 wire harness is grounded someplace. Doug
I switched the motor wires at the output of the switch. The problem goes away...I will bypass the wireset from the switch to the awning next to conclusivly prove it is the wire or terminations on the motor-side of the wire.
While I am glad it appears to be working I am very frustrated not to have found the root cause.
Thanks again for the tip. It was an excellent debug step that I hadn't thought of.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
